rmsailors
"Unable to load file" when printing over USB
Please help a Simplify3D newbie.
When trying to print a moderately complex model on a XYZPrinting Da Vinci Pro 3-in-1 (model is roughly: x 40mm, y 62mm, z 100 mm)
The print preparation process seems to complete smoothly, but when I try to print via USB, I get an error that says "Unable to load file" (paraphrasing).
I am trying to print with rafts and supports turned on.
Layer 0.20 mm
Top 4 layers
Bottom 4 layers
Outline shells 3
Honeycomb fill @ 60%
I am able to save to a file.
thanks in advance
cstraley
Re: "Unable to load file" when printing over USB
check what com port you are using then go to machine control panel and make sure that the baud rate and the com port is set right .
