Ender 3 Pro can't communicate?
Posted: Sat May 30, 2020 5:41 am
by fluffmonkey
I bought the software specifically to help me get my Z offset correct.
I've connected the USB cable to the PC (in the same port I use to successfully write G-Code to the SD Card) and it won't connect.
I've tried various BAUD rates, to no avail, and I don't know what to try next.
Connection log messages below:
Attempting connection at \\.\COM1...
  Testing plaintext communication protocol...
  Testing binary communication protocol...
  Testing alternate communication protocols...
  Connection failed.
Help??
Re: Ender 3 Pro can't communicate?
Posted: Thu Apr 22, 2021 12:43 am
by spletz
Same problem here. Did you find any solution? Does not seem to matter the baud rate, and I only have one COM port open COM1.
Posted: Sat May 01, 2021 9:39 am
by Ollinwen
the printer emulate a com port, so their is nearly no chance that it is on com1.
The com 1 is your motherboard onboard com, even if you dont have the bracket for it.check in your device manager and you will probably find a com 3 or a com 5, that will be the good one.
