Bed not heating
Posted: Sun May 31, 2020 12:54 am
by shane1234
Hello! In getting my model ready to print, I am setting the bed heater to 80 for the first layer, and 75 after. However, when I go to print, only the extruder heats up, not the bed. I'm not very fluent in G-code, but it seems like there should be something in there. Here is a snippet of it:
; **** Replicator 1 dual start.gcode ****
G161 Z F1200 ; home Z minimum
G92 Z-5 ; set Z to -5
G1 Z0 ; move Z to 0
G161 Z F100 ; home Z slowly
G1 X150 Y-70 Z30 F9000 ; move to wait position right hand side of the table
M127
M140 S-1 T2
M104 S240 T2
M133 T0 ; stabilize right extruder temperature
G92 A0 B0 ; zero extruders
G1 Z0.4 ; position nozzle
G1 X110 Y-70 E25 F300 ; purge nozzle
G1 X120 Y-70 Z0.15 F1200 ; slow wipe
G1 X110 Y-70 Z0.5 F1200 ; lift
; **** end of start.gcode ***
Any idea what I might be missing? Thanks!
Re: Bed not heating
Posted: Wed Jun 03, 2020 9:23 am
by S3D-Alex
The bed should be T0. Is there a reason this is T2? It may be a good idea to reload the stock configuration for this printer. You can do this by going to Help > Configuration Assistant.
