What's up w/ this file?
Posted: Tue Oct 07, 2014 8:26 am
by dennisjm
What happens for you when you try to slice this model?
For me (OSX 10.9 S3D 2.1.2) it never completes. The CPU goes to 100% and eventually I give up waiting and have to force quite S3D.
I know it has something to do with the supports defined at 1mm. If I remove those the model slices right away like we're all used to.
base2.factory
(1.2 MiB) Downloaded 204 times
Re: What's up w/ this file?
Posted: Tue Oct 07, 2014 9:11 am
by KeyboardWarrior
The amount of computation you're asking for is maxing your computer out for a part this large with 1 mm support. The resolution doesn't need to be 1 mm for a part this large and with 4 mm resolution it sliced in about 10 seconds on my laptop. At 3 mm, it covers more of the backend, but took about a minute to slice, so you can see that it goes up exponentially in computation required.
Posted: Tue Oct 07, 2014 9:15 am
by dennisjm
Yep I had already tried slicing with a bigger resolution for supports after I posted. Note to self to just make a mental note that support resolution on big parts causes massive increase in CPU time requirements.
