Speed changes and effects my print
Posted: Fri Jun 26, 2020 11:38 am
by tienbu
Hi guys I am pretty new to simplify 3d. I am working on a prototype and I noticed a change of speed in the upper part of the design is effecting my print. Do you have any suggestion how to fix this issue.
Re: Speed changes and effects my print
Posted: Fri Jun 26, 2020 11:54 am
by zemlin
Uncheck that box. Could create other issues due to overheating. Might need to leave it checked and adjust the settings.
There's a similar setting under COOLING which you can also look at. I have had to add points under the temperature settings to reduce the temperature when features get smaller as well.
Posted: Fri Jun 26, 2020 12:59 pm
by S3D-Jake
In the Speeds tab there is an option to have Simplify3D automatically slow down your print based on if the calculated layer time is below a certain threshold. Decreasing this threshold or unchecking the setting will remove this dynamic speed you're seeing in your preview.
Posted: Fri Jun 26, 2020 1:55 pm
by tienbu
Wow thanks guys for the super quick response I will check it out.
