Switching From one printer to another.
Posted: Mon Jul 06, 2020 9:33 am
by ZINN
Hi All,
New to S3D and new to 3D printing.
Question on switching from printer to printer.
I have CR-10S Pro V2 and CR10-Max, I have the FFF files for each printer, is there a way to have a drop-down or a way to pick the printer before opening STL file, or no?
Thanks...
Ron
Re: Switching From one printer to another.
Posted: Mon Jul 06, 2020 10:35 am
by parallyze
ZINN wrote: I have CR-10S Pro V2 and CR10-Max, I have the FFF files for each printer, is there a way to have a drop-down or a way to pick the printer before opening STL file, or no?
profiles can be selected within the process using a drop down list. As you can edit/modify/remove/add processes independent from the model files already loaded I'm not sure I understand the part "before opening STL file". If profiles differ you might have to rearrange the models but actually I don't know why loading the STL would need to be done before selecting a profile...
Posted: Fri Jul 10, 2020 10:30 am
by GarrGarr
You only need to specify the profile that you want to use before you select: Prepare your Print .
