Help, blobbing and filament unload
Posted: Fri May 10, 2013 11:48 am
i'm trying to print this cal.stl from the RepRap guys to show off Creator.
The FFF, gcode and cal.stl parts are attached.
I am using 32 bit Creator 1.1.2 over a short and shielded USB cable.
I've run this with a raft and got a blob right when the middle hole is starting.
It runs about 20mm of filament into the extruder, then pauses, then reverses the extruder and unloads the filament.
After this, it pauses, and will continue, but I am not sure how it goes, as I stop it.
I've run this without a raft, same thing.
I am using skirt as seen in the FFF, offset 2.3mm and 6 loops, for 1 layer.
What is happening?
Also, when doing the 6 skirt outlines, at the starting point for each loop, there is a retract and pause.
I think there should be a minimum distance required before retract is performed.
Dave
What is happening?
Dave
