cthenkhaus
Infill Settings
Hello all,
I'm a bit new to the 3D printing world but I have a Creatbot F430 and I'm printing some pretty thin walled parts. The problem I'm coming across is when I prepare to print my test run the parts don't look like they're being completely filled in. I have my infill at 100% so I'm not sure where my problem is coming from. Image
I appreciate the help!
S3D-Alex
Re: Infill Settings
It doesn't look like your image came through correctly. Could you try re-uploading this?
It may also be helpful to know that the Preview will more than likely not show a completely 'solid' infill layer. The infill is calculated by volume so even though the spacing may appear to have gaps the volume of plastic will completely fill the inner bounds of the part.
