I got a brand new FlashForge Adventurer III and printing with no issues using FlashPrint. Trying to move to Simplify 3D and it is failing 100% of time, the extruder is to close with bed. I believe the issue is the Z offset.
I did a calibration of printer manually (using LCD) and the level now is -0.5.
I tried changing in G-Code tab, manipulating the Global G-Code Offsets to +0.5mm but no effects.
I have two questions:
1) What setting I have to apply in Simplify 3D to avoid the extruder getting to close with bed?
2) Does simplify 3d supports controlling FlashForge directly using network (ip control) ?
Thanks,
