Having some issues with printer that I cannot figure out.
See the image below, printed with and without support. Is that Oozing? or bad bridging? ( I am new to this, apologies in advance)
Printer: Artillery X1 v4
Nozzle Diameter: .40 mm
Extrusion Multiplier: 0.96
Extrusion Width: .50 mm
Retraction Distance: 1.00 mm
Retraction vertical lift: .5 mm
Retraction Speed: 6000 mm/min
Primary Layer: 0.2000 mm
top Solid Layers: 5
Bottom Solid Layers: 5
Outline/Perimeter Shells: 2
Temperature:
E - Layer 1 = 210
Bed = 60
Cooling - 100% from layer 1
Default Print: 2400 mm/min
Outline Underspeed: 30%
Solid Infill Underspeed: 90%
Support Structure Underspeed:80%
X/Y Axis movement Speed: 6000 mm/min
Z Axis Movement Speed:1002.0 mm/min
Advanced:
Only retract when crossing open spaces
Force retraction between layers
Only wipe extruder for -outer-most perimeter
