dennisjm wrote:If you happen to save a factory file, then do some other stuff and choose different processes etc, then load your factory file again, the process bar will show whatever you used last. That can be very confusing. If you look at the actual settings in all the tabs though you'll see they are preserved according to how they were set when you saved.
It still saves a ton of time. I either name the Factory File so I know what printer/processes are in the file, or I will look at the starting script and figure it out from there if the process bar isn't telling me the correct printer.
Factory Files save time on positioning,support, every setting I tweak. But mainly I use Factory Files for multiple process prints, since it's always nice to be able to open the Factory File and remember exactly what settings I set for each part or for each region, even weeks/months later I've gone back to look at Factory Files.
