Hello, I have been using Simplify 3D for over a week now with a Magma 350 from 3D Online.
I have managed to print some stuff with the SD Card, the connection using a USB cable in order to use Simplify 3D remain unsuccessful.
Maybe someone will have an idea.
Simplify 3D Last Version
Mac Os 10.15.5 Catalina
Also tried with various USB Cables
The USB Cable is directly connected to the MacPro
This is the message I keep getting.
________________________________
Failed to connect to the machine.
Have you selected the correct port and baud rate?
Is your printer plugged in and turned on?
Many Thanks
