Simplify3D does not start anymore
Posted: Mon Aug 10, 2020 12:41 pm
by Feier68
after the purchase i installed it directly
and it worked well
but after a week it started to hang up when I started.
I don't know what to do.
it could be because of the graphic card because I had this problem with another 3D printing program please help or fix it
my graphic card : RTX 2080
Re: Simplify3D does not start anymore
Posted: Tue Aug 11, 2020 12:27 pm
by S3D-Alex
It sounds like you may need to change one of the display settings in Simplify3D. To confirm which setting to use, I will need a bit more information. I will explain the steps to follow below.
Please download the file below and then copy this file into the Simplify3D installation directory (typically located at C:\Program Files\Simplify3D-4.1.2).
https://www.dropbox.com/s/7b1gro9khc4s7 ... g.exe?dl=0
After you have done that, please open the Windows Command Prompt (you can do this by pressing Windows+R on your keyboard, then typing cmd.exe). Type the following commands:
cd "C:\Program Files\Simplify3D-4.1.2"
qtdiag.exe > C:\Users\%USERNAME%\Downloads\debugInfo.txt
That will export a file called "debugInfo.txt" into your Downloads folder. Please send us that file at [email protected] so we can recommend some further steps for you.
