touchthebitum
unable to switch off retraction
Hello
I'm struggling against turning off retraction. I checked off all menus but still active.
Any ideas ?
S3D-Alex
Re: unable to switch off retraction
In the Extruder tab of the Process settings if you uncheck the box labeled "Retraction" under the Ooze Control section this will ensure no retractions are placed in the gcode.
touchthebitum
already done but it doesn't work ...
S3D-Alex
Could you please send a gcode file where you are seeing retractions even when the retraction box is unchecked?
touchthebitum
Here it is
foot cube no retraction.gcode
(706.52 KiB) Downloaded 118 times
S3D-Alex
It looks like you have the option labeled "Include M101/M102/M103 commands" enabled. These are older commands that cause primes and retractions so it looks like these are causing retractions to still occur on your printer. Please go to the Gcode tab of the Process Settings and uncheck this box to make sure no retractions occur.
touchthebitum
Ok, I'll try it
Thanks
