How can I change extruder multiplier for last few layers using G-code
Posted: Mon Sep 14, 2020 9:04 am
by compnaion
Hi. I need to change my extruder multiplier for last few layers, because I am having a problem called "Gaps Between Infill and Outline" and while changing extruder multiplier solves the problem it makes the side surfaces bad. So, how can I change the extruder multiplier for last few layers using G-codes. Or rather is it even possible?
Re: How can I change extruder multiplier for last few layers using G-code
Posted: Fri Sep 18, 2020 11:10 am
by S3D-Mitch
This can be accomplished using the Variable Settings Wizard as described in the following link: https://www.simplify3d.com/support/arti ... f-a-model/
