Simplify 3D in Utimaker Extended 2+
Posted: Mon Sep 21, 2020 6:18 pm
by EinsteinPY
Hi, Anybody who tell me how put the extruder at the beggining of new job in one initial position but NOT 0,0? I will appreciatte some help...
Re: Simplify 3D in Utimaker Extended 2+
Posted: Tue Sep 22, 2020 11:28 am
by S3D-Jake
You should be able to utilize a G1 command in your Starting Script to move the extruder to a different position. G1 allows for several parameters. X Y Z and F are most important, especially if this is the first movement command being issued. You will also want to make sure the machine has been homed (G28) prior to executing a G1, as otherwise the outcome is less predictable.
For more on common 3D printing G-Codes: https://www.simplify3d.com/support/arti ... -tutorial/
For help in the Scripts tab: viewtopic.php?f=8&t=1959
