SPlit process
Posted: Tue Sep 22, 2020 10:29 am
by albertomarasco
I need to print from the 152mm height but this does not start from the bed. wants to start in the air at 152mm. I need it to start from the bed
. as I do?
Best Regards
Re: SPlit process
Posted: Tue Sep 22, 2020 1:46 pm
by S3D-Jake
A neat trick in Simplify3D is that you can, in instances like the one you've described, use the virtual bed surface as a cutting plane.
Double click your model to open the model settings panel for your selected part and lower the Z position 152mm. So if it currently reads 0 for Z you would change it to -152.
Here is a video on using the model settings panel: https://www.youtube.com/watch?v=i5rLVYpeoXU
