swimmerhair
Trying to captivate some hardware with XYZ DaVinci Duo 2.0 but running into crashing issues
Hey Everyone,
Like the title suggests I am trying to captivate some hardware (nuts) in my print. I could not get the pause script to work so instead I did two prints.
The first print, I printed up to layer X and stopped. I inserted the hardware and then ran another print where is started the print at layer X HOWEVER....
The XYZ printer I have does this tip wipe/purge feature that I can't seem to disable even when deleting the code from the starting script.
Has anyone every done this before? Am I on the wrong path?
Re: Trying to captivate some hardware with XYZ DaVinci Duo 2.0 but running into crashing issues
These earlier XYZ machines do not have the option to disable the purge/wiping behavior.
