Scars at layer start
Posted: Sat Oct 03, 2020 3:25 am
Hi All,
I'm pulling my hairs out for days now to solve a print quality issue. Any help is very appreciated.
I always have some ugly scars at exactly the same place where the layer starts (please see attached picture). Any ideas what can cause this?
Thanks, Martin
Print settings:
Thanks, Martin
Print settings:
; G-Code generated by Simplify3D(R) Version 4.1.2
; Oct 3, 2020 at 9:20:49 AM
; Settings Summary
; processName,Process1
; applyToModels,xyzCalibration_cube
; profileName,Cube - PLA
; profileVersion,2020-10-02 19:07:37
; baseProfile,Creality Ender 3
; printMaterial,PLA
; printQuality,Medium
; printExtruders,
; extruderName,Primary Extruder
; extruderToolheadNumber,0
; extruderDiameter,0.4
; extruderAutoWidth,0
; extruderWidth,0.4
; extrusionMultiplier,1
; extruderUseRetract,1
; extruderRetractionDistance,1
; extruderExtraRestartDistance,0.05
; extruderRetractionZLift,0.2
; extruderRetractionSpeed,3600
; extruderUseCoasting,0
; extruderCoastingDistance,0.1
; extruderUseWipe,0
; extruderWipeDistance,1
; primaryExtruder,0
; layerHeight,0.2
; topSolidLayers,3
; bottomSolidLayers,3
; perimeterOutlines,3
; printPerimetersInsideOut,1
; startPointOption,3
; startPointOriginX,0
; startPointOriginY,500
; sequentialIslands,0
; spiralVaseMode,0
; firstLayerHeightPercentage,130
; firstLayerWidthPercentage,130
; firstLayerUnderspeed,0.5
; useRaft,0
; raftExtruder,0
; raftTopLayers,2
; raftBaseLayers,2
; raftOffset,4
; raftSeparationDistance,0.14
; raftTopInfill,100
; aboveRaftSpeedMultiplier,0.5
; useSkirt,1
; skirtExtruder,0
; skirtLayers,1
; skirtOutlines,2
; skirtOffset,4
; usePrimePillar,0
; primePillarExtruder,999
; primePillarWidth,12
; primePillarLocation,7
; primePillarSpeedMultiplier,1
; useOozeShield,0
; oozeShieldExtruder,999
; oozeShieldOffset,2
; oozeShieldOutlines,1
; oozeShieldSidewallShape,1
; oozeShieldSidewallAngle,30
; oozeShieldSpeedMultiplier,1
; infillExtruder,0
; internalInfillPattern,Rectilinear
; externalInfillPattern,Rectilinear
; infillPercentage,20
; outlineOverlapPercentage,40
; infillExtrusionWidthPercentage,100
; minInfillLength,5
; infillLayerInterval,1
; internalInfillAngles,45,-45
; overlapInternalInfillAngles,0
; externalInfillAngles,45,-45
; generateSupport,0
; supportExtruder,0
; supportInfillPercentage,25
; supportExtraInflation,1
; supportBaseLayers,0
; denseSupportExtruder,0
; denseSupportLayers,0
; denseSupportInfillPercentage,15
; supportLayerInterval,1
; supportHorizontalPartOffset,1
; supportUpperSeparationLayers,1
; supportLowerSeparationLayers,1
; supportType,0
; supportGridSpacing,4
; maxOverhangAngle,50
; supportAngles,45,-45
; temperatureName,Primary Extruder,Heated Bed
; temperatureNumber,0,0
; temperatureSetpointCount,1,1
; temperatureSetpointLayers,1,1
; temperatureSetpointTemperatures,190,60
; temperatureStabilizeAtStartup,1,1
; temperatureHeatedBed,0,1
; fanLayers,1,2
; fanSpeeds,0,100
; blipFanToFullPower,0
; adjustSpeedForCooling,0
; minSpeedLayerTime,15
; minCoolingSpeedSlowdown,40
; increaseFanForCooling,0
; minFanLayerTime,45
; maxCoolingFanSpeed,100
; increaseFanForBridging,1
; bridgingFanSpeed,100
; use5D,1
; relativeEdistances,0
; allowEaxisZeroing,1
; independentExtruderAxes,0
; includeM10123,0
; stickySupport,1
; applyToolheadOffsets,0
; gcodeXoffset,0
; gcodeYoffset,0
; gcodeZoffset,0
; overrideMachineDefinition,1
; machineTypeOverride,0
; strokeXoverride,330
; strokeYoverride,330
; strokeZoverride,400
; originOffsetXoverride,0
; originOffsetYoverride,0
; originOffsetZoverride,0
; homeXdirOverride,-1
; homeYdirOverride,-1
; homeZdirOverride,-1
; flipXoverride,1
; flipYoverride,-1
; flipZoverride,1
; toolheadOffsets,0,0|0,0|0,0|0,0|0,0|0,0
; overrideFirmwareConfiguration,1
; firmwareTypeOverride,RepRap (Marlin/Repetier/Sprinter)
; GPXconfigOverride,r2
; baudRateOverride,115200
; overridePrinterModels,1
; printerModelsOverride
; startingGcode,G21 ; metric values,G90 ; set absolute positioning,G28 ; home all,M561 ; Disable any current bed compensation,G1 X150 Y150 F6000,G90 G1 Z3 F400,M400,G92 Z4 ; Reset z to 8 to allow jogging up to touch bed to nozzle,M291 P"Jog the Z Axis until the bed and nozzle are touching and click OK" R"Setting Z=0" Z1 S3,M400,G92 Z0
; Set z = 0,G90 G1 Z3 F400,M400,G1 Z5,M400,G30 S-1,M400,G1 Z5,M400,G30 S-1,M400,G1 Z5,M400,G30 S-1,M400,G1 Z5,M400,G30 S-1,M400,G1 Z5,M400,G30 S-3 ; measure probe height and set it.,M400,M500 P31 ; save trigger height to config-override.g,G1 Z5,M400,M280 P0 S160 ; reset Bltouch in case of errors,M557 X29:316 Y14:310 S20:20 ; mesh grid dummy,G29 ; mesh bed leveling,G29 S1 ; load bed mesh,M221 S100 ; set extrusion factor,G92 E0 F100 ; reset extruder,G1 X12 Y166 Z5 F6000 ; move to wipe,G1 E10 F300 ; extract 10mm filament to fill nozzle,G92 E0 ; reset extrusion distance,G1 X-8 Y166 Z3 F6000,G1 X-8 Y196 F6000,G1 X-8 Y166 F6000,G1 X-8 Y196 F6000,G1 X-8 Y166 F6000,G1 X-8 Y196 F6000,G1 X-8 Y166 F6000,G1 X-8 Y196 F6000,G1 X-8 Y166 F6000,
; layerChangeGcode,
; retractionGcode,
; toolChangeGcode,
; endingGcode,G91 ; relative positioning,G1 Z10 F3000 ; move Z up 10mm,G90 ; absolute positioning,G1 X0 Y0 F3000 ; move home,M106 S0 ; turn off cooling fan,M104 S0 ; turn off extruder,M140 S0 ; turn off bed,M84 ; disable motors,
; exportFileFormat,gcode
; celebration,0
; celebrationSong,Funky Town
; postProcessing,/Library/Frameworks/Python.framework/Versions/3.7/bin/python3 /Users/martin.ziegler/tools/bin/meshgrid.py "[output_filepath]"
; defaultSpeed,3600
; outlineUnderspeed,0.5
; solidInfillUnderspeed,0.75
; supportUnderspeed,0.8
; rapidXYspeed,9000
; rapidZspeed,1002
; minBridgingArea,50
; bridgingExtraInflation,5
; bridgingExtrusionMultiplier,1.05
; bridgingSpeedMultiplier,0.8
; useFixedBridgingAngle,0
; fixedBridgingAngle,0
; applyBridgingToPerimeters,1
; filamentDiameters,1.75|1.75|1.75|1.75|1.75|1.75
; filamentPricesPerKg,30|46|46|46|46|46
; filamentDensities,1.25|1.25|1.25|1.25|1.25|1.25
; useMinPrintHeight,0
; minPrintHeight,0
; useMaxPrintHeight,0
; maxPrintHeight,0
; useDiaphragm,0
; diaphragmLayerInterval,20
; robustSlicing,1
; mergeAllIntoSolid,0
; onlyRetractWhenCrossingOutline,0
; retractBetweenLayers,0
; useRetractionMinTravel,1
; retractionMinTravel,2
; retractWhileWiping,1
; onlyWipeOutlines,1
; avoidCrossingOutline,1
; maxMovementDetourFactor,3
; toolChangeRetractionDistance,0
; toolChangeExtraRestartDistance,0
; toolChangeRetractionSpeed,600
; externalThinWallType,0
; internalThinWallType,2
; thinWallAllowedOverlapPercentage,10
; singleExtrusionMinLength,0.5
; singleExtrusionMinPrintingWidthPercentage,50
; singleExtrusionMaxPrintingWidthPercentage,200
; singleExtrusionEndpointExtension,0.2
; horizontalSizeCompensation,0
