won't print some parts
Posted: Thu Oct 16, 2014 10:18 am
by xmhdx
i downloaded a moddel from thingiverse but when i click 'prepare to print' it won't show some parts.
Re: won't print some parts
Posted: Fri Oct 17, 2014 12:51 pm
by dsegel
Can you post a link to the model? Or it's number? This usually means there's a problem with the stl or scad file.
Posted: Fri Oct 17, 2014 6:58 pm
by jimc
yes when you see strange slicing behavior and areas filled in that arent supposed to be like in the first two circled item then 99% of the time its a problem with the model.
Posted: Sat Oct 18, 2014 8:48 pm
by KC_703
When this happens, usually a "reverse face" will fix the issue. If it doesn't, reverse the face in the desgn software. If manifold is verified, then filp an adjacent face and flip it back.
Posted: Mon Oct 20, 2014 3:01 am
by xmhdx
thank you for the replies, the ; reverse face' worked
