Support & first layer direction the same
Posted: Sat Oct 10, 2020 1:47 am
by brendanh
Need help with a configuration issue. I am printing an item upside down to minimise long support material. Most of the support starts at the bed with a small amount of the finish item shape beginning there also. The support is rectilinear and is in a is aligned in the X direction.
My trouble is that the first layer of the main item shape is also laid down in the X direction so the finished item always has a messy layer printed on top of the support. Is there controls to have the first layer rotated say 90 degrees to the support?
I've attached a pic of the problem. Apologies for the poor quailty.
Re: Support & first layer direction the same
Posted: Sat Oct 10, 2020 4:11 am
On the Support tab of the profile setting window, at the bottom RHS there is a control called Support Infill Angles which allows a support direction configuration to be specified.
This will by default have a single Zero in the table....which will indicates all layers in the X axis. Changing this to 90 will give all support layers in th Y direction. Adding entries will create a sequence of directions....so 0,90 will give support in alternate X, Y, X..etc by layer.
Posted: Wed Mar 08, 2023 3:13 am
by FastPrint
Dear All,
I'm using Simplify3D version 5.0.2 I'm unable to see the inf you have into the Support panel also after activating the Advanced view, here below my screen looks like:
could you please let me know how to see or where are located these options?
Thank you!
