GCode preview does not follow Z coordinate in a G2 code.
Posted: Fri Oct 16, 2020 11:47 am
by AlanKilian
The following GCode file should produce a 360-degree spiral, and when run on my Duet-controlled machine, it does indeed take this path, but when the file is previewed in Simplify 3D it shows a planar circle.
It looks like the Z coordinate of the G2 command is being ignored.
Code: Select all
G90 ; Positions absolute
G21 ; Units mm
M82 ; Extruder absolute
T0  ; Tool zero
G0 X100 Y0 Z50 F200
G2 I-100.0 J0.000000 X100 Y0 Z100 E5
Version 4.1.2
Re: GCode preview does not follow Z coordinate in a G2 code.
Posted: Mon Oct 19, 2020 4:06 pm
by parallyze
AlanKilian wrote: Fri Oct 16, 2020 11:47 am Version 4.1.2
Does S3D support G2/G3 in preview mode? The arc generation was removed in v2.0 over 6 years ago, it would be
a bit surprising to see the implementation to preview them correctly would have evolved since then...
Posted: Fri Oct 23, 2020 11:00 am
by AlanKilian
G2 preview works perfectly but it ignores the Z component.
