Printrboard G2 in Printrbot Metal Plus
Posted: Tue Nov 03, 2020 2:45 pm
by paulnord
I've replaced my controller board with the Printrboard G2.
Control works from Cura. But I can't get Simplify3D to talk to the device.
I think it has a version of the Marlin firmware. Not sure.
Can someone point me in the right direction?
Re: Printrboard G2 in Printrbot Metal Plus
Posted: Fri Nov 06, 2020 2:59 pm
by paulnord
I'm learning that the newer Printrboard uses g2core with some compatibility with Marlin firmware. It's fundamentally very different than the G-code command set used by most printers.
Is there any plan to support g2core in a future release of Simplify3D?
Paul
Posted: Tue Nov 10, 2020 3:33 pm
by S3D-Jake
I'm happy to document this new firmware type for our development team to look into.
Posted: Wed Nov 11, 2020 11:27 am
by paulnord
Thanks, Jake.
I'm not an expert. I'll tell you what I've learned.
g2core is based on drivers that are used for CNC machining.
The Printrboard G2 is a 32-bit board that provides nice smooth operation (microstepping) of the motors.
Some documentation of the board can be found here: https://github.com/abdrumm/printrbot-do ... tation.pdf
There is a firmware version here:
https://github.com/synthetos/g2/tree/edge/g2core
It can also run Kilpper firmware (https://www.klipper3d.org/).
Of course, if you're able to support this type of board, talk to one of the people supporting those codes and not me. :)
It works with Cura.
Paul
