Why is Simplify3D Non-Deterministic?
Posted: Fri Oct 17, 2014 8:10 pm
by dsegel
If I slice a model multiple times and save the GCode to a different file each time, it generates slightly different GCode in each file. Why is this? Shouldn't whatever algorithms it uses repeat themselves whenever it's run?
Re: Why is Simplify3D Non-Deterministic?
Posted: Mon Oct 20, 2014 1:59 pm
by KeyboardWarrior
There are some things that are randomized I believe. Under the Layer tab, for Start Points, there's the option to have Random Start points for all perimeters. Also, for the infill tab, there's a checkbox for Use random infill placement.
If both of these are randomized, you'll get slightly different slicing each time you slice, however imo not enough to noticeably effect prints results.
