I have an FLSUN Mini Kossel that i have been tinkering with off and on for a year or so. It is the only delta i own, i have 3 I3 types that i have running great. I put a 1.2 mm nozzle on it to see how fast I could print things that were not perfect detail required. I seem to be unable to print anything , no matter the layer height used, without large gaps. I have it currently set at 235 C for PLA to push more plastic easier for the larger nozzle, .4 layer height, 1.32 mm extrusion width, 6mm retraction @ 6000mm/min, 1.0 extrusion multiplier, 3 layers top and bottom and 3 shells. first layer height is 100%, first layer width is 125%, First layer speed is 50%, infill 25%, outline overlap 50% and allowed perimeter overlap at 50%.
I am using an SKR V1.3 with 2208 standalone drivers and Marlin bugfix-2.0. Am I missing something simple?
