Help with inverted cone print
Posted: Mon Nov 23, 2020 6:30 am
Hello,
I have a Dremel 3D45 and I managed to print successfully many times in Dremel Nylon an inverted cone (even without raft). However now I'm testing other type of Nylon (Fiberlogy Nylon PA12) and I'm having a repetitive issue at the beginning of the print. No idea what you call this: The interesting bit, is that the other side of the cone is smooth and fine: Any idea what is this or why is happening?
When I print the full piece, is fine, except for that lumpy bit at the beginning.
