dennisjm
[ADDED] firmware configuration switch with process
It would be nice if the firmware configuration could somehow be tied to the process. You know how on the gcode tab you can change the bed dimensions and gcode settings for if you are changing printers. That works great. However, I have two printers now and I found out that some of the gcode (like temperature change) commands are coming from the firmware configuration. So if I don't forget to change the firmware configuration before I export the gcode I end up with an invalid file sometimes.
Sort of annoying since the rest of the settings can all be updated when I change the process.
Re: firmware configuration switch with process
This feature was added in version 3.0
