Make Image to 3D work with jpg/jpeg
Posted: Fri Oct 24, 2014 2:35 pm
by 3Drasle
Or remove jpg/jpeg formats.
Just so others wont waste time as I did.
Re: Make Image to 3D work with jpg/jpeg
Posted: Fri Oct 24, 2014 4:56 pm
by jimc
i havent tried this feature since back in may sometime but i loaded a very good quality jpeg into s3d and it worked without an issue. this was obviously on one of the older versions so maybe something has happened since then. you and one or two others i have heard having the same problem with the jpeg.
Posted: Fri Oct 24, 2014 5:04 pm
by 3Drasle
jimc wrote:i havent tried this feature since back in may sometime but i loaded a very good quality jpeg into s3d and it worked without an issue. this was obviously on one of the older versions so maybe something has happened since then. you and one or two others i have heard having the same problem with the jpeg.
Hi jimc
Problem is that I can take the same jpg and convert it to png and then it works.
So I am sure the jpg is at fine quality.
