rolohaun
Filament Diameter and Extrusion Multiplier have no effect
I must be doing something wrong but I am printing on my Replicator 2 and too little material is coming out , changing the extrusion multiplier has not affect at all same with filament diameter I have changed it to 2.1 all the way down to 1.6 and nothing changes. I have measured my filament and it's 1.8mm but nothing helps. Are my changes not saving?
Re: Filament Diameter and Extrusion Multiplier have no effec
check the output gcode in a text viewer and compare the output gcode for the extruder and see if its different. ive never heard of the multiplier not working.
PrCTRL
may be your Nozzle is parially blocked ?
regards
Gerhard
