M104 M109 issues
Posted: Sun Dec 20, 2020 10:21 pm
by Work Horse XL
I’m having a issue with M104 M109 in the g code program. Simplify is address this as T1 when I have it set as T0 under the advanced sets.
Simplify is give g code
M104 S200 T1. This should be T0
M109 S200 T1. This should be T0
I’m getting errors from both on my Duet when starting.
Thank you
Re: M104 M109 issues
Posted: Mon Dec 21, 2020 1:41 pm
by S3D-Jake
Work Horse,
Can you please attach your factory file? (File > Save Factory File As..) This will help others to look into how you've setup the software and try to offer advice.
Thanks!
Posted: Tue Dec 22, 2020 10:13 pm
by Work Horse XL
Here is my factory file. I have edited the FFF under Firmware conf. but this isn't working correctly. Hope you have any answer for me.
Thank you
Posted: Tue Dec 22, 2020 10:32 pm
by Work Horse XL
So I made a new profile using the configuration assistant. I choose an Ender printer and changed the size for my custom printer and it's showing the correct tool in the gcode now. When choosing other and setup it up like that it is using T1 tool. Maybe this is a flaw or I done something wrong.
I have upload my file to help see the issue
Thank you
Work Horse
Posted: Tue Dec 29, 2020 5:30 pm
by parallyze
Work Horse XL wrote: Sun Dec 20, 2020 10:21 pm it set as T0 under the advanced sets.
Temperature -> Extruder 1 -> Temperature Identifier is set to T1
