Extra extrude after tool / extruder change
Posted: Sun Oct 26, 2014 7:56 am
Hi!
I installed and tested my copy of Simplify3d yesterday, till now everything works good. But I have one question right now.
I made an example part - just two rings(20mm diameter 0,8mm wall thickness 3mm hight) one placed on top of the other. I want to print the first one with extruder 1 and the second one with extruder 2.
It does work so far - the only problem is that it would need some extra exrude for the second extruder right after the first has finished. The first two layers lack of extruded material form extruder 2. Same problem as if you would start your print without perimeters...
So is it possible, when the first ring has finished extruder 1 retracts and extruder 2 travels to some outer position, extrudes about some mm and then starts to print?
Thanks.
Bye
Boris
Thanks.
Bye
Boris
