Dual Extruder Travel Issue
Posted: Tue Jan 12, 2021 3:10 am
by Pedrizzle
Hi all,
Im using simplify with my dual extruder printer. It has two toolheads which are offset around 100mm.
Im using this case as a simplified representation of the problem im experiencing. Im trying to print two cilinders each using a seperate toolhead. As can be seen in the attachment both toolheads still move through the other object. To me it would be logical if the left extruder would interact with the left model only and the right model with the right model only. Right now what happens after the toolchange the extruder brushes over the other colored part and can leave some blobs or will mix colors. Anyone know a solution. Thanks in advance.
Greetings, Pedrizzle.
