Have a double configuration for infil
Posted: Sat Feb 13, 2021 4:53 am
by Trad
Hello, sorry for the question, I want understand if is possile with simplify 3d to have a double configuration for the infill. I want use it for 2 cm hight and then not.
I'm printing a candelier , I want that in the base where the lamp is attached to have the infill 15%
Instead on the arm of the candelier to have vase mode or a simply 3 shell, without infill setting.
The reason of this choise is to print it with transparnt material, and if I print all with infill the arms have not a good effect when the light pass inside the arms...
https://www.thingiverse.com/thing:4624250
Some one can give me an advice to resolve this problem?
Re: Have a double configuration for infil
Posted: Tue Feb 23, 2021 10:31 am
by S3D-Jake
Have you seen this guide? https://www.simplify3d.com/support/arti ... f-a-model/
Setting up multiple processes should be all you need in order to do what you’re suggesting.
