How do i speed up the blue areas - see pic :-)
Posted: Fri Oct 31, 2014 8:46 pm
Okay you can see that most of this model is printed at a really painfully low speed. That i had no part in deciding.
The first part printed at the designated speed. Then for the easy vertical part it slowed right down.
This is simple rectangle with a channel. It doesn't need to print slowly. The trigger extension I can sort of understand.
But I'm noticing this extreme slow down quite a lot in models that build up rather than along.
So is there any way to speed this up ?
I can't find any settings that would account for this slowdown. I presume it's some automatic setting in the slicer engine.
For the most part the models that are getting this treatment could easily print much faster. That is what i want
Any idea how I change these settings ?
