printing an object with a hole in it
Posted: Mon Apr 12, 2021 5:46 pm
hello everyone! long time no post for me on this forum. i've been printing away... i just noticed this today working on a project. i have a rectangle with a hole in it. the geometry comes from 3ds max. i extruded from a shape of a rectangle with a circle in it. and as far as i can tell the top/bottom are completely flat/planar. it is a solid object, ie) water tight. it is not a boolean and only is 1 object not several attached together.
if i check merge all outlines into a single solid model, i get a solid box printed without a hole in the middle. if i un-check that, it slices as i would have expected it, with the hole. but i'm not sure if this is expected behavior? maybe it's the geometry?
