Domenick
MakerBot Replicator Dual and a Delta with Simplify3D
Hello everyone,
I am interested in using Simplify3D with my MakerBot Replicator Dual. Is this possible ?
I also have a Kossel Clear Delta printer from Kickstarter which you can see here:
https://www.kickstarter.com/projects/bl ... ta-3d-prin
Can I use Simplify3D on the delta too?
Dom & Shilo
KeyboardWarrior
Re: MakerBot Replicator Dual and a Delta with Simplify3D
Yep, both of these printers work with Simplify3D. The rep 2 is on the list of printers one click and your setup, and for the kossel, I'd recommend just using the SeeMeCNC Orion profile to start off with and use that as a base.
Domenick
Sorry I'm confused. the Rep 2 is not the Rep Dual. The Rep Dual is the wood construction with two heads. First was the Replicator then the Dual then the Rep 2, then the Rep 2x, and now the 5th generation. The supported printers states Rep 1, Rep 2 and Rep 2x.
Dom & Shilo
66tbird
It works with a Replicator Dual, aka rep1
