That sounds like a tough one to be honest. However, what you could do, what may really improve print quality would be to place a tall skirt around your part. Under the layer tab, set your skirt layers to 99999. It will generate a skirt as tall as your part, and this skirt generally does a great job at catching ooze.Accessdenied wrote:Hello. I have made two colors model, first part is flat square, white color, 0,6mm height with 3 layers of 0,2mm resolution, on this I should have black text with 0,4mm height. While printing black filament is making dirty my white base. So I need to print white base with cold second extruder, then rise up printer head, start to heat second extruder, manually clean white nozzle and start to print my text with black filament after some minutes. So its a question about such pause to clean white nozzle, cool down it and start to heat black filament head and continue printing on 0,6mm height. How to do it?
A S3D "Skirt" is pretty much what Makerware calls a purgewall?KeyboardWarrior wrote: That sounds like a tough one to be honest. However, what you could do, what may really improve print quality would be to place a tall skirt around your part. Under the layer tab, set your skirt layers to 99999. It will generate a skirt as tall as your part, and this skirt generally does a great job at catching ooze.
I just use the purgewall feature. It does a few things:Accessdenied wrote:Thanks, seems that no way to do that while they didn't make such option..
Skirt perhaps is an idea, but it doesn't improve material consumption for sure.
dennisjm
What is the way you use Makerware for dual color prints? Is there an option for pausing and head moving on Z axle or you just using standard options with additional walls?
Many other posts on this topic already. Supposedly the next version is going to address dual head printing.Accessdenied wrote:Well, I have printed it with Makerware also. Had some small black soil. So I set nozzle temperature at 200C. Bit too low and some small details didn 't print like I wanted (text on white surface), but it avoided dirties..
So I would like to wish for Simplify3D to make powerful tools for dual color printing, like smart algorithms for nozzle cleaning with purge walls, retracting and nozzle Z moving top to clean nozzle dirties manually (small pause on some height) and option to disable one nozzle heating when second one comes to print.. somethink like that. Then we would be able to make clean dual color print for very precise details liek buisnesscards.
