How to generate a support in this part?
Posted: Mon Sep 20, 2021 2:39 pm
by vwidmer
I got this file from thingiverse and when I generate a support in cura or pursaslicer it generates correctly automagicly when I try with S3d it does not seem to generate the support to hold the top spring. I tried to make one manually and it printed a mess :(
Any help, direction would be appriciated.
I am using a Creality CR10v3 printer.
Thanks
Re: How to generate a support in this part?
Posted: Thu Oct 14, 2021 5:49 am
by robenagetz
Can anyone help for this problem?
Posted: Tue Oct 26, 2021 10:53 am
by S3D-Mitch
It looks like the overhang on this part is quite small. I had to reduce the Support Pillar Resolution (Edit Process Settings > Support) to 1.00mm to get support to generate. If you would like to place custom supports instead, check out this video- https://www.simplify3d.com/support/vide ... tructures/
