CommanderB
[ADDED] Flashforge Adventurer 4
Hi, any idea when you will support the Adventurer 4? Or can I use the profile for the Adventurer 3 and just change the print volume?
Thanks in advance
klysons
Re: Flashforge Adventurer 4
Anxiously awaiting the same information, mine is on the way and I want to use it
sigbjornt
I also have this question. Just bought your software, because you list my printer as supported. Obviously you don't, since it's not listed in the setup window. :(
This is primarily a user forum....which is not the best place to ask this type of question.
Try this link to ask the question of Customer Support
dirq
Any updates on a Flashforge Adventurer 4 profile? I feel baited and switched. The site says it's supported but after I did an install, the startup wizard doesn't have the Adventurer 4 listed. I just contacted support so we'll see what they say.
dirq wrote: ↑Mon Apr 04, 2022 4:24 pm Any updates on a Flashforge Adventurer 4 profile? I feel baited and switched. The site says it's supported but after I did an install, the startup wizard doesn't have the Adventurer 4 listed. I just contacted support so we'll see what they say.
Our support team is happy to assist you getting setup with this machine and Simplify3D. Use the contact form and please include your Simplify3D account's registered email address or username.
https://www.simplify3d.com/contact
johnphillips1964
Did you manage to get a profile for your FlashForge Adventurer 4? I'm in the same boat - I purchased the software as it said it was a supported printer, and then it is not in the drop-down as a supported printer! Doesn't exactly fill me with confidence!
Version 5.0 has now added support for the FlashForge Adventurer 4 along with about 10 other popular FlashForge machines. You can download the pre-configured profile by going to Help > Configuration Assistant.
I should also mention that V5 now supports communicating with the Adventurer 4 over WiFi as well as exporting native .gx files with proper thumbnails and material settings. It should be a very big upgrade for all FlashForge printer owners!
