Xenon472
How to recover print setting from an old Gcode with more than one process
Hi everyone!
I recently changed my PC and forgot to back up the profiles I made in S3D, I now I can recover the setting using file -> import FFF, the problem is that the file I am trying to recover the profile setting had two processes in it (it was a gcode for a miniature and to print it faster I made a separate process for the base with a faster speed and a bigger layer and another process for the miniature itself) importing the FFF only recover the settings of the base process, but I am trying to recover the settings of the other process, is there a way to do it?
Thanks in advance!
Re: How to recover print setting from an old Gcode with more than one process
I know the horse has bolted......but may I suggest a way of preventing this happening again in the future.
A very simply routine to get into.......save a factory file for everything you print.
Disk space is cheap. Wigs are expensive!
PS For those who didn't get the joke.....when you get frustrated you "pull your hair out".
