Troubleshooting help needed Geared Extruder mod
Posted: Wed Nov 10, 2021 6:31 pm
Hi, I have a CTC Dual (Replicator 2 clone) that has been modded heavily over the years. Last year I removed the original MK8 dual extruders and replaced that with a single E3D V6 hotend and standard Bowden extruder. Around then I also started using Octoprint (with GPX plugin for gcode to x3g conversion). I only print using PETG.
My latest change is a 3:1 Bondtech BMG extruder.
I use Simplify3D to send Gcode files to Octoprint and Octoprint controls the print process.
The issue I'm having is that ever since I use a Bowden system, I need to set the Extrusion Multiplier to around 0.80 to get accurately (<1% tolerance) printed parts.
I've used a USB connection directly to the printer and Machine Control in Simply3D to check the extruder motor feed. 100mm filament feed is accurate with the Bondtech BMG 3:1 extruder when the E steps per mm were set at 415, the number Bondtech gives.
With the Extrusion Multiplier set at .80 and the extrusion width set to "Auto" (0.48mm width), prints are exact in size, and the layers bond very well together. It's just that the perimeter shells (I use 3) are somewhat separated and the bottom and top layers don't cover completely. Just as is the case when under extruding.
When I measure the width of a single printed line (on the bed) it's 0.50mm, so that seems accurate as well.
If I decrease the Extruder steps per mm to (0.81 x 415=) 337, I get exactly the same results when I set extrusion multiplier to 1.00.
Can anyone explain to me why my setup needs a 20% deviation to print fine?
