stewslash
the desired binary xg3 fije was not created
An error was encountered while running the GPX plugin.
The desired binary x3g file was not created.
Hi guys not used my printer for a while now when slicing using s3d I get the above message , I am running 4.1 software any ideas ?
FlashForge Creator Pro
using Mac
Re: the desired binary xg3 fije was not created
That error has something to do with the gpx.exe failing to create its output file...namely an x3g file.
Suggest you check a couple of things....write permissions in the directory the file should be written, and possibly a space issue.
