Issues On Layer Change
Posted: Tue Nov 23, 2021 1:34 pm
by doppable
I'm fairly new to the 3d printing as a whole, but I've got most things printing fairly well. As you can see I am having problems with not blobs or zits; but divot marks on the outside perimeter. I do not have coasting, wipe, and force retraction on layer change turned on.
Re: Issues On Layer Change
Posted: Sun Nov 28, 2021 3:44 am
by abc
Looks like you may benefit from some Extra Restart Distance. This setting is located under the Extruder tab. It will tell the printer to extrude a little extra plastic each time it un-retracts, such as at the start of these outer perimeters, to fill in gaps.
If this does not help things, then we will probably need a factory file to see exactly what is going on. It may also be helpful to know what model of printer you are using and any modifications that have been made.
