Hi All,
Just trying to work out how to connect the Prusa via USB to control it via the Control panel.
I had an Anycubic that worked off the bat, the Prusa is showing as connected but not allowing me to JOG the stepper motors etc and set temps.
When its connects the Prusa shows the little reboot screen like when you turn it on etc.
It connects at Baud 115200 and simplyfy is also sending the M105 commands and also not getting back the temp data
Mainly just wanting to test to see how accurate the filament is extruding.
Any idea on what else I may need to do or set?
