Outline Artefacts in Print
Posted: Wed Jan 05, 2022 4:57 am
I have a recurring problem with a range models of mine. The outlines of layers which do also have a solid infill on the inside are offset outside. The bigger the layer height, the stronger the offset. (pics attached)
To be more precise it is not just a offset, but it is slightly shifted too. Around the model it constitutes a ribbon, which isn't uniform but shifted from one side to the other. I first believed it to be a slicing issue, but I now tend to believe it's a mechanical issue. Still I can't find the cause of the problem.
I'm using an Ender 3V2.
I'd really appreciate any help and insights
Thanks in advance
Best, Sam
Thanks in advance
Best, Sam
