This software is AWFUL
Posted: Sat Jan 08, 2022 6:33 pm
by wraithrmm
Where to start:
* The simulator print's in thin air, telling me nothing about whether the print will fail.
* The supports are the worst I've ever seen generated. I have attached images, but there's no upload service for this. It left three independent sections (A hand dangling, the top and Bottoms of the Bow and the chin) of my minifigure model I put into it totally unsupported, like gravity does not exist.
* No Tree Structure Supports (even FlashPrint, which is free, has this).
I was expecting SO much more from this software, I'm gutted.
Re: This software is AWFUL
Posted: Wed Jan 12, 2022 6:00 pm
by RoboDLC
I think you should check the code that generated the STL files. Run it through Meshmixer or something similar and you'll find the problems there. S3D can fix some bad meshes with its tools, but you'd get better results from a better STL or OBJ file than relying on S3Ds mesh repairs.
be well,
DLC
Posted: Tue Feb 08, 2022 12:11 am
by erikinsobron
amazing, I like that
Posted: Tue Feb 08, 2022 6:57 am
by kellyhubbard90
Is this error can be fixed or not? I am thinking to purchase, Should i buy or not?
Posted: Thu Feb 10, 2022 5:02 pm
by RoboDLC
kellyhubbard90 wrote: ↑Tue Feb 08, 2022 6:57 am Is this error can be fixed or not? I am thinking to purchase, Should i buy or not?
This is a mesh error, not a slicer error. Many slicers will look bad with a bad STL or OBJ file. It isn't S3Ds fault.
DLC
Posted: Wed Mar 09, 2022 7:36 pm
by flyingdutch1969
Garbage in -> Garbage out.
