JoaoSilveira
Bridging: the layer is not flat
I am a newbie with 3D printing, I have an Anycubic Chiron and one model was not printed right. I just check the "Print Quality Troubleshooting Guide", but I could not find any help. I think that it could be a bridging problem, but the distance between the two points is only 4 cm.
Could anyone help me find why is the top not flat, like the bottom? It should be cimetrical.
Front view:
Top layer
Bottom layer
Simplify3D model
Many Thanks!
KevinSpiers
Re: Bridging: the layer is not flat
you need to activate "supports" on your S3D profile, this will add removable supports to stop your roof drooping down like that.
JoaoSilveira
Thanks, I will try
Instrumentation
The troubleshooting guide does have advice, but not a lot of specifics.
https://www.simplify3d.com/support/prin ... -bridging/
The ALL3DP blog goes into more detail about what specifics cause bridges to fail in certain ways:
https://all3dp.com/2/bridging-3d-printi ... t-bridges/
This Machine Bros blog has a very comprehensive guide to the different bridging settings and what they affect.
https://themachinebros.com/advanced-gui ... implify_3D
That part has a challenging bridge, so consider one or two very small manual supports as well.
