Page 1 of 2
Modifier Mesh
Posted: Sun Nov 16, 2014 2:21 am
by ashleywebster
The newest Slic3r has a feature called Modifier Meshes. It basically takes Simplify3D processes one step further. You can import another STL and lay it over your main model and then define slicing overrides where the two models intersect. So with Simplify3D processes you can change printing parameters as you move up the layers. With Slic3r's modifier meshes, you can change printing parameters for any part of your model, in any orientation. I really hope something similar comes to S3D.
I also want to say that I find Slic3r's implementation of this, the idea of having a common base of slicing parameters and then overriding specific settings, to be a bit cleaner. In S3D, if you have say four processes in a setup and then decide you want to change one common setting, you have to change it four times. So also consider implementing a method of 'locking' settings between processes and then just overriding the ones you want to change.
Re: Modifier Mesh
Posted: Sun Dec 07, 2014 11:42 pm
by dennisjm
+1. Infill is probably the biggest problem I've faced with the large print I've been working on.
Re: Modifier Mesh
Posted: Mon Dec 07, 2015 7:10 pm
by Carl
I was going to post a similar request. I use this all the time in Slic3r and is a big miss from Simplify3D.
Re: Modifier Mesh
Posted: Fri Jul 15, 2016 2:20 pm
by Carl
Is there any feedback from S3D on this request?
Re: Modifier Mesh
Posted: Wed Jan 25, 2017 4:45 pm
by ianlee74
Carl wrote:Is there any feedback from S3D on this request?
@S3D ??? - I just discovered this feature of Slic3r and am envious. Being able to modify parameters on a layer by layer level is great but being able to define it at the union of two objects opens up a whole new box of capabilities. In case you don't know of the feature we're speaking of, you can see it here:
http://slic3r.org/blog/modifier-meshes
Thanks!
Ian
Re: Modifier Mesh
Posted: Sat Feb 04, 2017 11:34 am
by SPRINGFIELD-JACK
+1
Re: Modifier Mesh
Posted: Mon Mar 06, 2017 7:53 am
by anthem
I too would love to see a similar feature come to S3D. I've been very pleased with S3D's slicing but not so pleased with its configuration. To be perfectly honest, the more accurate slicing and the multiextrusion prime towers are the main reasons I use S3D instead of Slic3r, and this is just one more reason I still have to fall back to using Slic3r sometimes.
Re: Modifier Mesh
Posted: Fri Jun 23, 2017 5:38 am
by TurbulantCalm
Count me in on this one as well.
Re: Modifier Mesh
Posted: Tue Oct 17, 2017 5:15 pm
by jbbiomed
Yes!
But seriously, does S3d actually read these?
Re: Modifier Mesh
Posted: Thu Sep 20, 2018 10:39 am
by Carl
Still no reply....?
