FOX2156
How to use script to move up Z at specific layer??
Hello! i am having a issue when printing PETG, it's too sticky and if i don't manually move up the Z at second/third layer, the material will build up on the nozzle and dropped eventually. I couldn't find any script that allows the Z move up at second/third layer during the printing. Tried G1 command but it will move up then back to original position, also tried "REPLACE", but it only changes Z height at specific layer and it doesn't change all Z height relatively. (for example, if i repalced the layer 2 height to 0.7 from 0.4,on the layer 3, the Z height will the 0.6, install of 0.9mm.
Please help, thank you
gwhite
Re: How to use script to move up Z at specific layer??
If you are building up gunk on the nozzle tip, do you have Z-lift enabled? I've found that helps a lot. I prevents the tip from dragging across the print when it's traveling to a new location over existing material.
airscapes
sounds like your nozzle is too close to the build plate to start or you are way over extruded. I only see this on my machine when I am over extruding as my starting height is always calibrated correctly. Could be short coming of your particular machine if the bed is not flat with .02 mm you could have high areas that cause your problem.
Create a 2 walled calibration square that has wall widths the same as your extrusion widths and make it 3 mm tall. Then print it. If extrusion multiplier and starting Z offset is correct the square will measure 3mm hight +- .02 and will be the correct width +.02
Good luck!
peter009
GB Whatsapp DownloadCheck this topic..
viewtopic.php?t=4522
Hope it will help you.
FOX2156
Thanks guys, the height has been calibrated, i will try the Z-lift see if it fixed the problem.
Thank you
