james891
Support Wall Thickness
Hi guys,
Is there a way to adjust the wall thickness of supports or is it limited to nozzle size? A printer of mine(with super volcano) has a .6nozzle but I'm measuring .8 thickness of the support wall. Another printer (standard cr10) has a .8 nozzle but the supports are .6mm thick. How does that make sense? Thanks in advance,
James
Re: Support Wall Thickness
Extrusion settings for your support structures are determined by the selected Support Extruder. So the extruder controller in the extruder tab will have the associated extrusion width, extrusion multiplier, retraction, etc settings. You can even create a new extruder controller in the extruder tab so you can specify separate extrusion settings specifically for your support structures!
